my mt 09 have a problem
hello all my friends. my name is ibrahim, i am writing this article from izmir city of turkey. I'll tell you what happened to me, maybe we can find a solution together. In December of 2021, I owned an mt09 with 2014 model abs. I rode it for about 3 months with pleasure and after 3 months I realized that the condition of my chain is very bad, so I thought I would wait until I get my salary and change it as soon as I get my salary. But until I got my next salary, the chain went off the rails and broke the block. For months, I had mail correspondence with the Yamaha Turkey team, the Yamaha UK team and the Yamaha Europe team, and they said that the only solution to the problem was to talk to the Yamaha Turkey team again. In my meeting with the yamaha turkey team, I was told that "if you go to a yamaha dealer, your problem will be solved and you will be offered different payment options." But when I went to the yamaha dealer, the only thing I was told was that the cost of 5500 dollars was covered by me in one go. (I am explaining in dollars to be more understandable) Let me summarize as follows, the minimum wage in Turkey is 300 dollars and I am a Turkish young man working in a factory for minimum wage. Even though I wanted to explain that I could not cover all of this expense in one go, no one helped. Now, the Yamaha Turkey team has not been responding to my e-mails for months. I can't find any authorized person or a contact person for myself. I can't contact anyone. In short, my motorcycle, which I have been dreaming of since I was 14 years old and bought by working on cold days, is rotting in my garage and there is nothing I can do... I will leave my contact addresses below for you, if anyone can help me, please contact me. Survive, ride a motorcycle for a lifetime...
You can contact me via message on my phone or you can write on whatsapp. I wouldn't recommend calling because my english is bad...
+90 (506) 668 02 88 e-mail: ibem417@hotmail.com instagram: @ibrahimeksii
thanks for everythink
madca-- Nouveau membre
Re: my mt 09 have a problem
la 1ère fois vers 1980 CB 750 (rupture de chaine):
démontage par moi même / soudure argon du carter par le garage / remontage par moi même
la 2ème fois vers 1995 TDM 850 (absence, par l'ancien propriétaire, de la rondelle frein sur le pignon de sortie de boite):
démontage par le garage / fourniture d'un moteur d'occasion (5000 km) par le garage / remontage par le garage cout total 5000 frcs
je pense qu'il ne faut rien attendre de la marque dans ce cas car il s'agit d'un défaut d'entretien de la transmission secondaire et cela est indépendant de la situation et de la capacité financière du propriètaire de la moto
benim için sorun olan tüm masrafın tek seferde talep edilmesi, istedikleri ücret 18 aylık maaşıma tekabül ediyor...
taksit veya senet yapmıyorlar???? asıl sorunum bu...
madca- a écrit:dostum haklısın ben zaten ödeme yapmayı kabul ediyorum. bu benim için sorun değil
tamam ama o zaman bu forumdan ne yardım bekliyorsun?
çünkü özellikle mali ve ekonomik bir sorununuz var......
Ah non ! Au nom de l'amitié franco-turque, on va essayer d'aider Madca !
Pierre Boubou et madca- aiment ce message
t'as une idée derrière la tête ?JP43 a écrit:M...., ils m'ont changé mon forum MT 09 ... Je dois être tombé sur un site étranger ...
ZEBRAZOMA a écrit:madca- a écrit:dostum haklısın ben zaten ödeme yapmayı kabul ediyorum. bu benim için sorun değil
Quel instruction ce Zèbre !... tu parles le Turc comme tu l'écris ?
donc études puis vie la bas ....i! y a bien longtemps.....
Madca c'est pour toi l'opportunité de converser ... moi vos conversations, heureusement que Google est mon ami !ZEBRAZOMA a écrit:ben ouais, Pégaze et couramment en plus.....les langues, c'est ma passion
donc pour converser en turc ca risque d'etre pas facile.......sauf si Marcus s'y met !
il m' a confié le pratiquer dans certaines conditions (il a besoin d'outil, je crois.....mais chut, c'est un secret)
Je parle un dialecte turc lors des rencontres fortuites, et néanmoins consistantes ,entre un marteau et mes doigts. Parfois même, ce dialecte turc peut être confondu avec du serbo croate même a de l'inuite. Mais c'est une erreur. Si tu t'en bien l'oreille, tu entendra très bien que ces du turc.......enfin, je crois
pegase22, iron man, ZEBRAZOMA et Pierre Boubou aiment ce message
marcus06 a écrit:Damned......je suis trahi
On entendra que de vilains jurons (éloignez les enfants !)... en patois du midi !.... con !
objectif atteint
et pour une bonne pratique du turc, google traduction fait bien le taff
bon mon Pégazou, moi je plie les gaules, ca mordera plus ici
chez notre dénoyauteur d'olives !
(pas oublier le con !)
mec tu as raison, j'accepte déjà de payer. Ce n'est pas un problème pour moi
Le problème pour moi c'est que toutes les dépenses sont demandées d'un coup, le salaire qu'ils veulent correspond à mes 18 mois de salaire...
ils ne font pas de versements ou de billets à ordre ???? c'est mon principal problème...
ok mais alors quelle aide attendez-vous de ce forum ?
car vous avez un problème financier et économique notamment......
Lui trouver un carter peut être...?
après, là bas, ouvrir et remplacer le carter est peut être accessible...
après, je ne sais pas si c'est possible chez lui... à la marseillaise
faire bêtement tomber la mob d'en haut de la falaise de Cassis et la déclarer volée... enfin, pas dans cet ordre.
merci Googoltraduc !
Et vous savez ce qu'il vous dit le dénoyauteur d'olive....Hein, vous le savez ...putin con!!!pegase22 a écrit:n'empêche que ça fume de la calebasse
Et ça va pas être du turc sans déconner !!!!
salut Maitouk,
avec Marcus (en MP) on penserai (ou pencherai) plus pour (a 2 lettres prés):
Lui trouver unE carte
ca nous a vaguement fait penser aux mails que l'ont reçoit parfois ou l'on apprend que l'on a gagné une forte somme ou bien que l'on peut sauver la vie d' une personne.......
d'ou ma question
et depuis?...... plus de nouvelle du détroit des Dardanelles (ca , c'est juste pour la rime )
on verra bien si il y a une suite et une demande plus précise...................
pegase22 et Tracer 900 52 aiment ce message
Merci google :
mec peut-être y a-t-il quelqu'un sur ce forum qui peut me dire à qui je peux m'adresser
Tu peux juste commander les pièces et faire la réparation toi même.
https://www.bike-parts-yam.com/yamaha-motorcycle/850-MOTO/2014/MT09/MT09/46364
%100 kusurlusun, Yamaha sana asla yardım etmeyecek.
Sadece parçaları sipariş edebilir ve onarımı kendiniz yapabilirsiniz.
crois tu aussi que lui (comme moi :ou pas....) a également vécu là bas dans sa jeunesse? (pour y suivre une "petite")
qu'est ce que je me suis bien marrer, Marcus, sur ce coup là (et Pégaze aussi surement )
Le Zèbre peut se glorifier d'avoir glissé une olive au dénoyauteur !.
La vengeance du Centurion sera terrible !
pegase22 a écrit:L'arroseur arrosé ?
Je suis pas mince, pas sûr que ça rentre ...
pegase22, ZEBRAZOMA et Pierre Boubou aiment ce message
